Wireless HDMI/VGA from PC to Projector
28 May 2008
Crewe aka Crewhan
Hi Guys,
Need a quick and cheap solution to a problem..
Have a pull down screen with epson projector, but the workstation that needs connecting to it is the other end of the classroom, ruling out a wired vga connection.
I need to be able to dual output the pc onto the epson projector wirelessely via either VGA or HDMI.
VGA would be perferably.
Thanks
Cable upto roof then drop it down at projector quick and cheap. Wireless is an expense for something that really wouldn't benefit.
One thing I neglected to mention is that the teachers desk / workstation is in an open space nowhere near the wall, and a ceiling to floor pole is out of the question :(
IT paper 2 multiple choice, please select ONE answer
Question, I have been lumbered with an impossible job of connecting a PC wirelessly to a projector with a budget of 50p
Answers
a) refer problem back to the bright spark who decided to have a projector installed without being able to connect it up to the pc.
b) refer problem back to the person who ordered the projector without a wireless option
c) give yourself 100 lines,
d) dust off the OHP in the cupboard
e) none of the above
