wireless hdmi
14 Dec 2005
what is the best solution (or solutions for different budgets) for sending sky HD to a 2nd TV, also being able to change channel from the 2nd TV
only looking to watch 1 screen at a time so no point in multiscreen, also I'd need to get the wires from dish to STB with multiscreen, although having said that if there are issues with hdmi sender/receiver's it may still be an option
You can get Wireless HDMI senders, though in my experience they really aren't great.
Only options I can think of would be a Magic Eye, HDMI over Ethernet.
You could also use an iPad or Laptop (if you have Sky Go) and then plug the device into your TV.
For the price, multi room is still a great option, but again, limited with cables.
ive tried sky go with my ipad and apple tv but it doesn't work, not wanting to be messing about with cables really
might just get an SD video sender, the HDMI ones are a bit pricey unless they're perfect!
