Hi All.
Hopefully I am in the right place
I am in need of some advice, and I apologise in advance for my lack of technical knowhow.
We have a bit of a strange scenario, so I will try and outline it as simple as I can .
We currently have 4 projectors, all in separate rooms. We only use them to watch movies and TV. We would like to have a headphone basestation for each projector which is each capable of pairing 6 headphones. The basestation will be out of direct sight so I believe this rules out infrared?
Each basestation needs to operate individually to the selected 6 headphones, however the headphones will need to be interchangeable between basestations ( so no use in buying four different brands ) the headphones themselves would ideally be powered by changeable battery ( not rechargeable ) and doesn't really matter to much on the sound quality.
I have contacted a few companies but they arent that helpful and only point you in the direction of their website..
If there is anybody who could offer any sort of advice on this it would be great.
Thanks
Thanks
