Wireless headphones, £75
13 Jan 2006
Wigan
Hi
looking for some wireless headphones for gaming.
I hate having the wire across my desk so i want wireless.
What should i be looking at?
£75 ish.
how are Sennheiser RS 120?
Do you care about sound? Because 90% of the wireless headphones I've tried have been shocking.
Some companies are getting the hang of wireless, UE9000 if you can find a bargain somewhere was basically the UE6000 with a big bag of features including wireless.
In your price range You are better off sticking two cups to your ears with a bit of string attached. Go wired and enjoy quality! Brainwavz HM5, K167.
If you don't care about sound quality too much try some of the Panasonic's.
Def want wireless, i hate the wires across the desk or floor.
Ive seen sennheiser rs 180, so i may just wait till pay day and splash a bit more. Amazon have them for £170 but will see if i can get them cheaper.
i know they are double the budget planned :p but screw it!
you want a flubit account then? i'll send you a link in your trust just go through that and sign up.
they basically give you a discount on anything which can be bought off amazon.
usually a 6-12% discount which on £170 will be quite a decent amount like up to £20 off.
