Wireless Headset - Gaming/Music/No Mic
26 Aug 2012
So my SteelSeries Arctis 7 died and wanting to replace with some good wireless headphones.
I don't want a mic on them as I'll use them outside my office.
I also currently have K702 with FiiO E10K which is great but wires...
I'm after over ear, closed ideally (i know the 702s are open but my office is a little noisier than previously),
My main concern is they mostly connect via BT and with gaming as 50%+ I don't want to experience audio delays (is this a thing these days?)
Looking around £200 mark but pretty flexible on that.
TIA
I searched and saw maybe these are an option but are pretty expensive?
Audio-Technica Ath-DSR9BT Wireless Over-Ear
Sennheiser RS175
I think you want something with Aptx-LL low latency codec capable, not many seem to have this. I've narrowed down my search to the Momentum 3's from Sennheiser. These can be used wired or wireless and the USB-C also allows for connection without a separate DAC.
will take a look at those, they look pretty comfy! £350 though eesh :)
Not sure about latency as it isn't a concern for me.
But I'm going for the Sony xm4.
For me is a split between gaming, music, conference calls ..
Probably 15 percent calls
55 percent music and 30 percent gaming
trying the RS175 (amazon return probably :)) so far they seem nice, no noticeable latency and connect via SPDIF but sadly no option to connect to mobile etc. I already have some nuraphones for my travelling anyway.
I can vouch for the Sony WH1000XM3 for sound quality (it's a warm soundstage, great for bass) and comfort, and the noise cancellation is second to none. You can have them fully bluetooth, or use a standard 3.5mm cable. The XM4 set is out but I've not tried them, but I'd be cautiously optimistic that they improve on the XM3.
