Wireless headset recommendations.
8 Feb 2007
Looking for a new wireless headset with mic as my last set broke.
Budget £200 max.
Main use is gaming/movies.
Ideally should work with PS4 (bonus not required). Just needs to be comfortable for long sessions.
Been looking at Logitech G930 or Corsair CA-9011125/Corsair CA-9011127 (not sure on difference other than colour).
Any advise is much appreciated.
I love my Steelseries H Wireless. Quality is fantastic and they are very comfy. Also work on PS4's etc :)
Not sure on the price because I've had mine a while but I reckon you can get a set for under £200.
Logitech G930 is one I've had for a few years now, still plodding along but I have changed the Ear pads and top pad as they were falling apart a bit.
It does seem to disconnect every so often (once every 4 hours or so) and reconnect but if you Google the issue its down to the 2.4Ghz wireless (so if u sit next to your router you may have it more).
Overall its a brilliant headset,I think it can be had for £99 somewhere and I would probably buy another if mine broke :)
Picture of mine with the new pads:
Thanks all,
I went for the Steel Series wireless H.
My friend has the Logitech G930, he has the same issue with random drop outs but highly recommends them other than that.
what's the battery life like on the steelseries H ? I'm using corsair vengeance 2000 atm and it will last about 8 hours or so
So headset came yesterday.
Overall impressions are good. Mic is apparently very clear, I've not been able to test sound quality as I'm still using on-board sound card.
I used for 12 hours and battery was still going (running on empty) but you get a second battery in the box.
