Wireless Headset With Mic
2 May 2007
Im looking for a wireless headset with a microphone, I dont really play any fps anymore atleast not seriously so i care more for sound quality as in listining to music though them rather than directional sound. I game for a LARGE chunk of the day so the headsets life would have to be decently big or beable to be used while on charge.
If anyone has any ideas of where to go please let me know, Also i dont mind a gaming headset at all - my budget is no more than 160 pound.
Thanks in advance guys.
wireless = crap sound quality
no matter what way you put it wireless is not for audiophiles.
also sets with mics are generally poor in the SQ department too.
your best option is to get the most expensive sennheisers (wired or wireless) you can afford and a cheap desktop mic. but i would say go wired for sure.
I had some £110ish wireless Sennheisers for a while and I also had a £70 something wireless logitech headset around my neck to get a wireless mic lol
Was fine till the crap logitech headset snapped :/ Anyone would think I had a really wide neck!
After all that I decided to come back to wired and bought my MMX 300
Seconded.
You're only going to get a microphone with wireless gaming headsets. Such things will be crap for music.
If you really need wireless, get some of the digital wireless Sennheiser's. Preferably the RS170's. They can be had for £150 or there about, leaving a tenner for a microphone.
As Psycho Sonny said, wired is better. You'll get much better sound quality for your money, but if you do really want wireless, get something worth having at least, not some half baked headset.
