Hiya currently have a wireless router at home, but my pc is out of range from it, but I have a canle coming to my room. But I am getting a PS3 and it is nowhere near a wireless network or a network cable
The options I have are use the Asus Solo-Ap (ie use my pc as an access point), but means it always has to be on or in sleep. But it doesn't work to well in Vista from what I have gather (atm use Vista as my primary OS).
The other option is to buy another wireless router but for my room. This seems better as I dont have to leave PC on. But I have never setup a network before and will it be okay having a network within a network? We dont really share files too often and if I need too can put it on a DVD tbh. But will this work the best and if so just get a cheap bog standard wireless router?
The third options seems getting a switch and a wireless access point but seems twice the money and then I will have two boxes!
Thanks for the advice.
