Hi,
Im running out of ideas and i know you guys are a smart bunch so looking for some help.
i need to create a wireless hotspot for about 100-150 clients and i am having trouble on thinking up of a solution.
there are wireless WLAN controllers you can get for this type of thing but the thing is, my client wants it so there is only one user/password per day that they need to write on a whiteboard, so everyone can connect.
I've tried out a zyxel Wlan controller and they only allow 8 concurrent connections for one single username/password connection on the device itself, and zyxel told me for anything else i should go for a RADIUS server.
now the problem is why buy a zyxel device if i can just have a radius server instead?
well the problem with radius is that i cant change the password everyday. it would need to be scripted and that takes time, an engineer and money.
do any of you have experiance of RADIUS and know of a solution that can change user/password everyday automagically?
