wireless internet Handhelds
8 Jan 2005
Worcestershire
Hi, my new business venture requires me to have access to the Internet while on the move. I have little knowledge of completely wireless connection solutions and am unsure what best suites me.
I was thinking about a decent PDA/Handheld with a good amount of processing power, but I'm not sure how it will connect to the Internet.
wifi,GSM, bluetooth? all a little confusing :confused:
Cheers
Well you can discount Bluetooth really as that is more about personal access to peripherals like phones, printers headsets etc.
That leaves you wi-fi in all it's incarnations (802.11b/a/g etc.). This allows you to connect to a hotspot within a few hundred metres. In practice this means it'll only be good if you're spending your time in Airports, coffee bars, train stations etc. where hotspots exist. Or else on client sites where they have wireless enabled internet access.
For a truly mobile internet conneciton you're going to need to use the mobile phone networks. It's not cheap. You can either use a good mobile phone effectively as a wireless modem or get a PDA/phone combined. Another option, which I would recommend, is a datacard. Use a full size laptop and buy a data card from vodaphone or orange. This slots into your laptop and gives you internet access nearly anywhere. Getting it on contract with a good amount of data transfer included would be an economical way of staying online.
Whichever solution you go for with the mobile networks, they will use the fastest connection they can make normally, starting at 3G (near broadband speeds) and then stepping down to GPRS (landline modem speeds) and then down to something horrendous!
BigT, thats made things a heck of a lot more clear in my mind!
looking into the options you gave me it seems these 3G data cards look just the ticket. monthly costs wouldnt be to bad at all if I kept within the usage limits. as you say there pretty much base broadband speeds with x8 faster than dial up, which is pretty speedy.
Thanks for the help mate!
