Hi,
I have an ongoing issue that I hope someone can shed some light on. My current situation is this:
I live in a rural area that didn't, until recently, have wired internet access. Unofrtunately my landlord insists on sticking with the old wireless provider so theres nothing I can do about that. Now, the service they provide is pretty fast however the issue I have is with how the network is set up.
The signal is beamed out from nearby mast and picked up by a box (AP, router?) attached to the side of the house which then comes into the house via ethenet and it is this which I connect to the eth0 on my Edgerouter X.
Now everything functions as it should except I have trouble connecting to people on the Playstation 4. I believe this is due to a possible double NAT on the network although it happens even when I plug my PS4 directly into the ethernet box and take my own home network out of the equation.
I have emailed them about this issue, mentioning the ports then PS4 needs open, to which I recieved this response:
'The ports the list refers to are outgoing ports, there are no filters at all on any outgoing ports on our network . Our network has a 'related' firewall rule which means it will accept incoming traffic that relates to an outgoing connection. This covers 99.9% of requirements.'
Now I don't have any access to their side of this network, I only have control over things inside my home, and I was wondering if anyone could offer any advice on how I can elimiate these connection issues? It's normally when I'm trying to connect to people in games that use P2P networking, server based games on my PC are fine.
Apologies for the long message, this has been going on for a long time now and I've never actually been able to get to the bottom of it. I've tried port forwarding, DMZ, UPnP2 although my limited knowlege of networking means I'm not sure if I set these up correctly, or if they would even make a difference.
Would really appreciate any help on this. Thanks!
