Wireless issue
Permabanned
31 Dec 2006
Xbox 360
Okay, i'm going to try and explain this best I can :p
Theres my dads pc, which has the main internet connection. Theres then stepmoms they both link up to the same wireless router (Linksys WRT54GS (v4) Wireless-G Broadband Router with SpeedBooster) via ethernet
Then theres me, using wireless pci card (D-Link DWL-G520+)
Problem being everytime I try any game online (WoW, CSS) it's fine for around 5 minutes then internet will just lose connection :|
I have no idea why, I've put router into DMZ, added WEP, updated the firmware on router. it's really starting to get on my boobs
I have 'Wireless Zero Config' turned off, using wireless card's software - dunno if this will help, but heres the software thing: http://img26.picoodle.com/img/img26/4/1/17/f_Untitled2m_51e6937.jpg as you can see, signal and link quality is good.
Its fine when surfing etc im only in the next room too
so if anybody has an idea as to why it's being stupid, please help ;)
thanks
The solution is to never turn of Wireless Zero - wireless adapter software is almost always crap and Windows should be used exclusively for wireless management.
