Wireless Issue...
14 Oct 2007
My dad found his old AJP laptop in the loft the other day and was throwing it out, so I took it off him and started it up, works fine, the only problem is, I can't get an internet connection.
He has a BT Voyager Wireless Card you put in the side. When I first tried it, It was coming up saying Limited or No Connectivity, so I looked online for a fix, and I had to click on 'Run' and type something in, and then change something to make it connect but now I can't get it connected and I can't find the link I seen it on, or remember the command...can anyone help?
I'm trying to connect to my Dlink router (I can connect to my Dlink from my mobile and PDA, just not the laptop)...
Thanks
Try disabling security on the wireless connection and see if it connects. Also, if it only supports wireless B then make sure your wireless signal is broadcasting a B signal.
