Hey guys
Sorry for another thread
I just can't connect using my wireless card at all, it's driving me mad.
I've downloaded ndiswrapper, installed it using a tutorial and ran everything correctly, ndiswrapper shows that both the driver and hardware is present
So I went into Network Config and it found my wireless card in there to which I installed. But now, it comes up with the error message
"SIOCSIFFLAGS: file or directory not found"
I looked into this problem and found it is due to missing firmware, which I downloaded from the prism54 site which was recommended. Got the firmware, put it in the folder /etc/firmware first, same problem, then /lib/firmware and again same problem
This is really getting to me now as I really wanna get my Linux PC online but
Just no joy
ifconfig wlan0 up is the command that gives the SIOCSIFFLAGS error by the way
Also, it's not conflicting IRQ address's either which is the other problem associated with that error as I ran a command to check IRQ addresses and thats all ok
If anyone can help you will be considered Linux gods lol
