Wireless Keyboard Mouse Combo
20 Jun 2007
Looking for one of these but not sure which one would be the best buy. Not looking to spend silly amounts of money but need something that has a lot of functions and has a good conection, dont want it cutting out or freezing.
Any ideas?
Cheers
If you're on a budget have a look at the Logitech EX 110. I use it with my Linux box and work laptop. Its a nice budget wireless combo. If you got more in your budget than have a look at either the Microsoft or Logitech offerings. Both have their good and bad points.
Personally I prefer Logitech as their customer service have been excellent but its a personal choice.
Yea been lookin at the Logitech ones they seem pretty good. Not really got a budget in mind atm. I jus dont wanna spend over the odds on something that cant be justified, but dont mind spending a lot if it means im getting a good deal.
I'd go into some shops and try some keyboard/mice out. It'll help you see which ones you like and then post back and people can help narrow down the choice for you.
