wireless keyboard mouse problem!
28 Nov 2003
Manchester, UK
I have the following:
http://www.mobilewhack.com/trust-ds-4700r---wireless-laser-mediaplayer-deskset/
Trust DS-4700R - Wireless Laser MediaPlayer Deskset
It is pretty much brand new, and has new batteries, however for sum bizarre reason the keyboard sometimes tends to not work. I have to repeatedly press a key for it to work and then again it goes off and the next key stops working.
Most the time its fine (like now) but is the thing faulty? The mouse has a switch underneath to switch it on and off the keyboard however does not. I am using windows xp and I just dug out the box for the deskset and installed the drivers from the cd to see if this helps but it didn't.
Does anyone have any ideas why the keyboard is playing up :confused:
