Wireless lighting Relay
14 Mar 2005
Here and There...
When we had our kitchen designed we didn't pay enough attention to lighting and something I now really want to add is lighting above the cabinets. This is easy on one side as all the wiring for the under cabinet lights is on top of the wall cupboards so I can just add the over cabinet lights and switch them with the same switch as the under cupboard lighting. On the other side of the room we have power above the cupboards but no switching as this is used for some automatic lights in a larder cupboard and a sonos speaker. What I'd like to do is add a wireless relay so when the over cupboard lights on one side are switched on the over cupboard lights on the other side come on as well.
I'm sure the product I want exists but my google-fu is burying me in home automation products and smart phone control that I don't want! Yes I know the correct solution would have been to install them properly in the first place but burying more cables is a no go!
If I'm understanding your set up correctly then these will do it -
Replace current under cabinet switch with one of these - https://www.tlc-direct.co.uk/Products/QUE11W.html or one of these if you want to separate the under from over - https://www.tlc-direct.co.uk/Products/QUE12W.html
Then add one of these to each zone you want the switch to activate - https://www.tlc-direct.co.uk/Products/QUR303.html
They work really well and are better than the battery operated Wise ones I've installed before however I'm not sure on their longevity yet seeing as the switch depends on friction to create a signal which could easily wear I guess.
Perfect except I don't want to replace the switch is is right next to a socket and is a matching model!
What I want is a sender that sender that hangs on switched side with the under cabinet lights to turn the over cabinet lights on the other side of the room on and off at the same time.
