Work related, hope thats ok!
I've got to cover 16 museum galleries with wireless coverage. been out and done a site survey and I think its going to need a few repeaters etc along the way as the walls are thick, there is plenty of Rebar inside the concrete walls and also a lot of old lighting with high discharge that will cause interferance.
Its not possible to get ethernet to most of the wireless points so they are going to have to repeat off each other etc (wiring is impossible due to Grade 1 listing etc)
So, firstly is it possible to have, say, 8 access points to provide coverage? Its possible that I can connect 2 to ethernet but more likely only one.
Also, within reason, what would you suggest is the best (read most reliable) kit that I can do this with? Dont have cisco style budget btw!
Thanks in advance
Lumey
Thanks in advance
Lumey
