Hi Guys,
Over the last year or so a majority of the kit I've got is capable of Wireless N but my trusty old Linksys ADSL Home Gateway (WAG200G) is only capable of G.
Was thinking of investing in a new N modem router but don't want to slow the new network down by having the slower devices still connecting to it.
Presuming I could:
Link the G router to the N router via LAN cable
Set the starting IP address on the N to 192.168.1.101
Set the IP of the G router to static on 192.168.1.100
Set the N to 'N-only'
Set the G to 'Mixed' - to cover if I have any B devices needing connecting.
Set up two SSIDs (e.g. Linksys N and Linksys B) with the same Pwd
Set the DHCP server on the N to enable and disable it on the B router
Reconnect each specific device
Just thinking am I being silly and the latest wireless routers do not suffer slow down if you connect an older device to them, would the above work or is there a better solution?
Thanks
Presuming I could:
Thanks
