Wireless modem + cable
Well if you are on NTL cable, then no.
You need a cable WiFi router.
On that router you plug the RJ11 from the micro filter on a phone connection into it, and then it is the modem and router.
You need one that takes an RJ45 from the modem, and then solely routes WiFi and LAN, and is not a modem.
InvG
WRT54G-L of Buffalo WHR G54S or the High power version would be my suggestion as it can be purchased new for under £25.50 + del the Buffalo is a bargain (though I can't tell you where as it's not OCUK). OCUK do however sell the WRT54-GL. If you have an existing router you should be able to use the adsl router you've linked to as a 'dumb' access point though.
