23 Sep 2008 at 20:52 #1 TurnipHead TurnipHead Soldato Joined 13 Mar 2007 Posts 6,575 Location UK Ok, I gots me a wireless mouse and keyboard. When I reformat will I have to connect them via usb or will they work straight away? Thanks.
24 Sep 2008 at 07:19 #2 Farore Farore Associate Joined 11 Aug 2007 Posts 536 Location Preston, Lancashire They should work as long as the reciever is connected to the PC.
24 Sep 2008 at 09:29 #3 misterPK misterPK Soldato Joined 18 Apr 2007 Posts 3,736 Location Probably in a river somewhere You might have to check you've got the right USB setting in your BIOS if it doesn't work straight off. PK!
24 Sep 2008 at 13:46 #4 TurnipHead TurnipHead Soldato OP Joined 13 Mar 2007 Posts 6,575 Location UK Thankyou.
