Wireless mouse with charging dock.
10 Jan 2012
Sunderland, UK
Hi, my dad is after a wireless mouse with a charging dock or a cable that can plugged into the mouse to charge it.
Already looked at the logitech performance MX, but its too expensive, he just wants a simple mouse with no extra functionality with a way to charge the mouse easily.
Thanks.
Problem with charging docks is you can't use the mouse while its charging. I had the old mx revolution with the dock and currently use a performance mx with just a lead. The cable charging design is a lot easier if you forget to charge it.
As someone who's had both the MX1000 and currently an MX Revolution, I can confirm that charging docks are a hassle, you'll regularly end up with a mouse with a flat battery. Not helped by the fact that the battery indicator on the Revo turns off after a few seconds so you never notice it, and the software does a terrible job of telling you the battery is low.
An MX Performance is next on my list but they're still pricey despite being discontinued.
The Ouroboros is a joy to use, The charge lasts roughly 10 hours, More depending on what your doing, You can disconnect the charge dock and plug the cable straight into the mouse should you run low on battery in the middle of a game, I've honestly got nothing bad to say about it :)
Ok, thanks, I like the dock and cable option. It may be time to retire my G9X
