Wireless 'N' connection only works in 'B/G'
23 Feb 2003
Edimax 7728ln with Virgin Router (D-Link DIR-615)?
I have a Virgin Router (D-Link DIR-615 Wireless N), and have just installed an Edimax 7728ln Wireless N PCI card.
If I set the mode to "B/G/N mix", the card connects to the router just fine, and allocates an IP address. But I just can't get any internet access, nor access the router (192.168.0.1). Tried edimax config, and Windows config (XP SP3). Also set router to just "N", but same problem.
If I set the mode to "B/G mix", everything works just fine...
So it's not a massive problem, but I just can't get "N" to work. Any suggestions? Is it to do with N standard incompatibility?
