Phnom_Penh said:It's probably that the large number of connections to the router through bit-torrent are causing it to crash.
Skilldibop said:Should be a setting in your client for BT to set max connections. 255 or less should fix it.
Skilldibop said:that 200 is probably per torrent then. You may need to adjust that according to how many torrents your dealing with. I'd google your router and find out how many connections it can do and then do a bit of "poke it and see" diagnostics.
"poke it and see" meaning increase the connections towards your router's maxmum for say 5 open torrents and keep going till it crashes. then knock it back a bit and leave it.
