Anyone? I really need to get this sorted. I think I need PCI but I don't know where to start really. Some are on different networks and are not compatible sometimes and some aren't compatible with windows 7 :S confusing stuff
PCI-E is probably the best option as they're usually faster and have a better range.
Just go browse through OCUK and look at some PCI network cards which are compatible with your OS.
It's not hard to spec a decent one, they all pretty much do the same thing, see
