28 May 2011 at 22:56 #1 Zeal01 Zeal01 Associate Joined 26 May 2011 Posts 46 Hey, Looking for a wireless card that will allow internet connection (upstairs) through a (downstairs) router. Only component I really know nothing about. Thanks tons, Zeal
28 May 2011 at 23:00 #2 panyan panyan Soldato Joined 13 Mar 2011 Posts 7,484 Location Bada Bing Zeal01 said: Hey, Looking for a wireless card that will allow internet connection (upstairs) through a (downstairs) router. Only component I really know nothing about. Thanks tons, Zeal Click to expand... wireless g, n?
28 May 2011 at 23:05 #3 Zeal01 Zeal01 Associate OP Joined 26 May 2011 Posts 46 panyan said: wireless g, n? Click to expand... Yes. Seriously though, no idea, please explain.
28 May 2011 at 23:15 #4 Zeal01 Zeal01 Associate OP Joined 26 May 2011 Posts 46 Ok the Router is a F5D7231-4 Wireless G Plus Router. If that helps.
29 May 2011 at 00:51 #5 BarKeep BarKeep Associate Joined 18 Oct 2002 Posts 582 Location N E Essex I've used these, to replace USB sticks, with good results: http://www.overclockers.co.uk/showproduct.php?prodid=NW-010-TP&groupid=46&catid=1597&subcat=1622
29 May 2011 at 01:00 #6 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,529 Location Spalding, Lincs Wont hurt to get wireless-n if/when you change your router. http://www.overclockers.co.uk/showproduct.php?prodid=NW-014-OK&groupid=46&catid=1597&subcat=1622 Make sure you have a pci-e slot free if you choose the above.
29 May 2011 at 10:38 #7 Zeal01 Zeal01 Associate OP Joined 26 May 2011 Posts 46 Don't think I'll have aspare PCI-E slot, should have a spare PCI, so how does this http://www.overclockers.co.uk/showproduct.php?prodid=NW-002-DN&groupid=46&catid=1597&subcat=1622 shape up?
29 May 2011 at 11:56 #8 3dcandy 3dcandy Soldato Joined 18 Jun 2003 Posts 4,368 Location Rugeley that will be ok...hopefully you'll get a decent signal strength else it will be back asking questions again I guess...
