Wireless Network Card Help Urgent Please!
on the laptop have you pressed Fn and the Fkey with the wireless symbol to connect
and not being familiar with your wireless router, is there a pairing button
also go to start key on PC then click on "Connect to" then> Wireless Network Connection.
>Look for product name or SSID
>Highlight
>Click on Connect
>type in WEP KEY found on Wireless router
>then click connect
>also tick boxes for options "save network settings" and box for "Start Automatically"
Thers several versions of the card, those drivers are for revision C and from an australian website are you sure thats the card you have? Thers some chacne vista already has drivers for the card without a download as well.
I have the revision C card and also my Wireless laptop (XP SP2) can connect fine, but its my PC that doesn't work (Vista Home Premium x64).
Its so annoying :(
It cost £15 but doesn't work! Want to buy a new one that works but this card was confirmed to work on x64 so the same may happen again :(
I had a similar problem with a new laptop my sister asked me to install Vista on.
It was my first go at Vista and it nearly drove me mad, dunno if this will work or even why it worked, but here goes.
Log into your router and and make sure UPNP is switched on, I think I actually disabled it, rebooted the router and enabled it agin just to make sure.
Switch off and unplug router and modem, power down PC, leave it a few mins.
Plug in modem, let it boot up, connect to router.
Plug in router, let it boot up, boot up PC.
Also, cos I aint convinced the above is gonna help ya, I'd try disabling the router's firewall and make it public, security off, so anyone can connect and try again. That way you can rule out bad config as far as security goes.
Lastly, have you checked for new firmware for your router..?
