Wireless Network Card
15 Jan 2006
Scotland
My friend wants to but a ADSl broadand wireless router such as the Netgear DG834G for a PC which is only a few months old. Does she also need to buy a wireless network card or does it come with a receiver that can plug into her existing network card? Does a USB wireless router/modem simply plug into the USB port?
Axel
yes she needs to buy a wireless card or wireless usb adapater for the pc or you can connect the router to the pc via the ethernet cable.
usb modems are not really that good and if you want to connect it straight to the pc then there is really no need for a wirleess router?
