Apologies if this is a regular question, but atm I have very little access to the net as I've just moved into Uni and I don't have access in my house. So although it does take little time to search, I don't have the time to go through all the results to get to my answer, sorry.
So to my question,
so far I have used a standard ethernet card for access to the net and haven't bothered with anything fancy, however now I am going to have to purchase a wireless network card as I can't put wiring into my rented house. I am a big downloader but my network will be limited to a 16mb connection, however I will probably be needing some sort of LAN set up also. So my question is what sort of network card should I be looking for or could you recommend anything specific? The router will be free through Sky if that helps.
So to my question,
