Wireless Network Card
15 Sep 2006
Liverpool, UK
Hello,
I have never been on a wireless network before with my desktop computer before. I know I need a wireless dongle or a wireless network card. I am just wondering what can you recommend?
Basically I want it to be good and cheap. So, any help would be appreciated!
Thank you :)
i would side with a good PCI card to be honest, simple to configure aswell.
you can get ones rather cheap now a days
What are you going to connect it to? Any particular requirements (e.g. drivers for x64)?
Good and cheap are mutually exclusive but if it's what you want, you should be able to pick the cheapest possible option from the shop site...
