wireless network card
Permabanned
4 Sep 2007
Newcastle upon tyne
ok i have just finnished formatting a family members pc, they have a wireless card but i have no way of known what brand it is to get the drivers.
i have looked on the card itself but it has no manufacturer and only info i could get off it was a serial code for a memory chip! i also used everest to obtain the pci hardware number but this has not helped either... machine is running xp pro can any 1 help ?
Only way i can think of.
Connect to internet using a network cable.
Go to device manager.
right click your wireless card and select "update driver", this should give an option to search online.
Been ages since i used XP, but should work.
Hope you get it sorted.
