Okay I've been planning on improving my home network setup. The current setup is like so:
If you can figure out from that, I have two wireless networks in the house, one for Internet and th other connected to a network (wired) printer in another room. The PC is connected to both all the time (since it's using CAT5 & Wireless) but the laptop needs to switch between the two.
All very messy and akward.
What I thought of doing instead was this:
Perfect I thought one network for all. Nope, problem is how can I route traffic through the router, to the access point then onto the printer? I can't as far as I can see. The printer in theory could communicate with the PC and Laptop, but not the other way round.
So, my question is what can I do instead? The access point does support bridging modes, but it seems to imply that it only works with WEP, not WAP. Can I do anything with routing on the Router to direct calls to the printer IP via the access point IP? Or is that just crazy talk.
Any help would be fantastic guys.
The laptop is set to not respond to pings. Doh. Turned it on and my changed setup works perfectly.
