wireless network newb needs help
19 Jun 2003
i read the faq but need some basic info
at the mo i have 4 pcs on my adsl line all connected through an old ASUS AAM6000EV plus a hub
what do i need to get up and running with a new wireless network
is it easy to set up
is the connection as stable as wired network
are there any security issues
Im quite happy with my current network but i probably need to get a newer router
what one is good
can i have a network which has 4 pcs connected via cables and use wireless just for my laptop
thx
thx
right well. yes you can have 4pc's and a laptop (on wireless) on one router. there is no need for a hub.
simply wire each pc to the router. plug the phone line in. open the config page of the router and input all your ips details i,e user name, password, dns and mac and vpi (all avaible from your isp) and away you go.
on a security note it is adviseable to encyrapt your network. this can be done on the router and the network key will have to entered in each on the computers using the router.
other than that it's as easy as 1 2 3!!!!
have fun!
