Hi chaps, my first post here so please be gentle
After much tweaking I've finally managed to get my Netgear Router up and running on vista 64 and it works fine for the PC it is connected to.
The problem lies when I'm trying to network between two PCs in the house that are quite far apart and on seperate floors. I have one of these as an adapter on the other computer and it seems like it's not within range. I plan to try the adapter PC a little closer first to ensure it is a range issue and not anything else. (Having it closer wouldn't be a long term solution however).
What I'm asking is - if it is purely a range issue how can I remedy it? Are there recommended signal boosters that I could use a median point that wouldn't require an additional PC etc?
Thanks in advance for replies.
