Wireless network setup with AOL?
1 Jun 2004
Chryston, Glasgow
Hi,
A friend wants me to setup a wireless network in her home- to share the AOL gold connection with two pc's.
Having looked around the net, i found that some routers have problems with AOL- does anyone have any advice/help on how to go about setting up such a network?
Regards
Netgear DG834G (v2)
Works perfectly fine and AOL gives you install guides and support
Goto AOL Keyword: Home Networking (i think it is) should give you details.
Best idea. As long as it'll let you reduce the MTU (don't bother with PPPoE, it's a waste of time), you're fine - but getting a router that AOL will give you support for might very well be a good idea.
i think as long as it supports pppoe you will be ok
Nope.
i had read some sites and some people seemed to have trouble viewing secure sites. I think i will go with that netgear router as its supported.
Thanks for the info
regards
Mark
tolien said:
Because you need to change your MTU to 1400 with AOL.
I concour, It is the issue with AOL requiring an unusually low MTU that causes sites like ΣBay and some secure sites to not load or load weird.. But as i said pop along to AOL help pages at that keyword and it should set you straight.
