Im round my mates and want to connect to his wireless network on my pc but its asking me for the network key which we dont know. Is there anyway of finding out the key from his computer? Cheers.
Open up the routers web interface and there should be a wireless config page, and it should be somewhere in there. whats the model and make of the router?
Check the SSID isn't hidden and that the network type is mixed incase he's connecting on the wrong protocol.
Safest bet if your not sure what's going on is to reset and follow the manual from scratch. (make sure you have any ISP info handy before resetting tho.)
