Wireless NIC
9 Dec 2014
Hertfordshire
Made ultimate noob mistake by assuming my new motherboard had built in wifi... it doesnt :p
Need a NIC, I want to be fast, very fast, and have the best signal reception as there are a few thick walls between my router (Home Hub 4 sadly...) and I.
There is a shiny ASUS one, £65... ouch! What's the difference between this one and a lower end one?
Any recommended ones? Or is it a case of buy a cheap one, there all about the same.
I have the ASUS 3*3 AC Wi-Fi integrated into my X99 mainboard and it’s very good, has good range and is fast. I also have the ASUS 2*2 AC Wi-Fi integrated into my Z97 mainboard and that is also very good, I get my max internet speed on both (152/12 Mb). ASUS do 3*3 and the 2*2 AC Wi-FI Pcie cards that should be the same as the one included with the mainboards, think the 2*2 AC one is about £45. The 3*3 one has much better range as I have used them both from the same place.
i have the Asus PCE-AC56 Wireless PCI-E Dual Band Network Interface Card work soo well and love it to bits and is only £42.97 on Amazon so i say get that if you what to go all out
