Hi All
Can anyone give me some advice on what i should do in my case, basically I've always been hard wired to the network in my house, but things have changed and I will be moving to a unit that we have had built in the garden which is approx 30 to 40 meters away from the wireless router ( Router is about 6 years old ).
I got hold of some homeplugs breifly from a friend to check on a laptop using an extenstion lead outside and after a speed check i got 1.5mbps, but didnt get to try online gaming. ( 5 to 6mb wired on upto 20mb with Zen )
Need to know what would be the best way to go ? If it is wireless would it help with a more upto date router ?
Hard wired through the house isnt an option at this time.
Note - That the PC is used for online gaming most the time.
Thanks
Thanks
