wireless or rj45 lead?
  • Thread starter Thread starter P90
  • Start date Start date
P90
P90
16 Oct 2004
Iam on virgin media 20mb i get 17 on pc but 360 only get under 10mb so whats best wireless or rj45?
Uh... I'm guessing your xbox is connected wirelessly? If so then ethernet would be better...
Standard 54Mbps wifi might not be able to actually achieve a throughput of 20Mbps, so if you want to make the most of the internet connection, you're going to want it wired.
i second ethernet unless its too far from the router - then the only way you will get higher speeds would be to go for one of those homeplug setups that passes the signal through you house electrical wiring
