wireless pci card recomendation please
What operating system and router will you be using it on?
I got one of those about 2 weeks ago and had nothing but problems for the first 1 1/2 weeks.
I dont know if it will be the same on your setup as mine was windows 7 64 and sky.
The problem I had was that it would not connect to the router for long if at all.
I checked all the drivers and power management, even reinstalled windows and still the problem was there.
After a LOT of reasearch I found someone saying that there is a problem with the N network and WPA PSK TKIP encryption. I changed mine to WEP and it has been fine since and not a single drop out.
If you do get that one (which other than that has been really good on signal) you should be fine, just remember that you might have to play with settings for a while. :)
they're out of stock on ocuk so getting it elsewhere should pick up tommorrw is the one after addvertoised on oc
