Wireless plugin USB "thing" for an XP Laptop
19 Oct 2002
Hi
i'm good on normal wireless and good old cable but i'm going to have to run XP on a partition on a new Win7 machine
and due to drivers etc. for the built in wireless i'd like to find out if there is a plug-in "thing" via USB that I could get that would be XP compatible to connect to my router
it would do for what I want
Thanks
UPDATE
just seen this on the OC site
Edimax EW-7612UAN 300Mbps High-Gain Wireless-N USB Adapter [EW-7612UAn]
http://www.overclockers.co.uk/showproduct.php?prodid=NW-193-NG
sounds like it would do if XP compat or does it load software from the device itself
when pluged in like those mobile broadband dongles do ?
