was looking at the linksys wireless g print server
does this work seperately to a wireless router (so you just need to have wireless on your laptop/pc) or do you need to have a wireless router as well as the print server ?
It acts like its own laptop so to speak it connects to the modem so anything on the network can use it. But not 100% here but i think you can use it without a modem as it acts as a server
You do need to have a wireless router as well I believe. You then set it up to connect to your wireless network, and it can then be access by anyone.
Edit: Or a wired network if it has an ethernet connection.
