Hey,
I have a pc that is fairly close to the wireless router (Netgear 802.11g WG603) and there is no walls seperating the two. The PC with the Belkin card(802.11g) in it, picks up the network on maximum strength at 54mbps, no problems everythings fast. If i go away for a couple of hours then come back, the lights on the PCs network card have gone off and the networks gone, if i search for the network it dosnt detect it, however if i disable the connection and then re-enable it the lights come back on and i can connect to the network again. Im fairly sure it isnt a router problem as i have a laptop that uses the same router with no such problems. I am using the windows networking software rather than belkins, does anyone know why this could happen? Is there some kind of inactivity network cut off
Thanks for any help,
Jack
Jack
