Wireless range advice.
20 Oct 2002
Hi guys. A friend of mine has his ADSL modem and wireless router in his office at home plugged into his main pc via Ethernet. He has a laptop that he uses round the house wirelessly but the signal gets a bit weak when in the kitchen. He wants to be able to use it reliably in there so asked me for advice on how to extend the signal. I never have much luck with my wireless so I thought I would ask you guys! The wireless router is a buffalo. They any good for range or could just replacing the router with a more powerful/better one do the trick? What is the best wireless router for range on the market (doesn’t have to be cheap)? I also thought about using home plug kits to have a wired network to the kitchen and then another wireless access point in there. Although, that would mean there would be effectively 2 wireless access points for the laptop to choose between and would that be a problem or does roaming work OK like this? Does anyone have any pearls of wisdom they could let me have? Any advice appreciated.
Thanks.
