Yo,
I bought this yesterday, picked it up from OCUK
http://www.overclockers.co.uk/showproduct.php?prodid=NW-028-TP&groupid=46&catid=1837
And set it all up, was pretty simple. However, it does the opposite of what i want. Instead of extending the signal, it's makes wireless unusable. It extends the range for a few seconds, then cuts the signal off for 1 minute, then resets itself, and does the same thing over and over.
Anyone have any experience? Is there a router setting i should be using to allow use of it?
