Hi folks,
I currently have a Belkin wired set up through out my house connecting to 3 pc's, but now i need to move one of the pc's into a shed at the bottom of the garden.
As a result, I am considering replacing the belkin router with a wireless one, but since i dont really know much about wireless networks i was hoping someone could advise me on which router and PCI wifi adapter to get. My budget is about £70.
The current cable modem and router is situated in a room at the front of the house, and i think this is where it will have to stay. I was hoping to keep the 2 pc's that are staying in the house connected via Ethernet to cut down on cost and to keep it all easy, while utilizing the wireless for the pc in the shed.
I dont think the shed is more that 120ft from the router, and ive looked at routers that are capable of broadcasting at this range, however i am always concerned as I dont know if the walls of the house will affect signal etc.
Ive been looking at the industrial looking linksys routers that are priced at about £35....are they any good?
The router will be used for internet gaming, downloading music and general Internet useage.
Regards
Matt
Regards
Matt
