Wireless Router For Virgin
8 Nov 2003
england
Hi Guys
Can anyone recommend a good Wireless Router and card that will work with virgin
Thanks Guys
the net gear one i got with my 50mb i think is really good signal is great its in my lounge and i get 100% anywhere in my 3 story house ..
its a WNR2000 i think.
-Infernox
Hi
Just found out that you only get a free one with virgin if your L or XL. im only M so no freeb for me :rolleyes: So are all the linksys ones good. Or should i be looking for a model
linksys are a sub brand of cisco. and cisco equipment is the best equipment i have used,
so i would have no doubt recommending something that was made by them.
not cheap no but its like monitor, you can reuse in future systems so its a long term investment not short term upgrade, still your call though, depends how big your place is and how thick/material of walls etc, for me it was worth investing in N class technology, and as I say linksys are in my experience THE most reliable, never had a problem with any of their products unlike most other brands which have had a niggle here and there
Are the Belkin and Getnet Routers any good. Or should i still be looking at linksys,cisco,and net gear
ive never heard of getnet so i wouldnt bother with them, and belkin do some horrid routers my last was bad so never again,
linksys and netgear, cisco far to expensive to go in at home .
When i signed up to M a few month ago i got a netgear router...and ive just upgraded to L and they sent me another router which is a Dlink 615 wireless N router...didnt have to ring or anything it just arrived lol
On a Virgin cable, had problems with Linksys / Netgear routers, so with gaming and consoles, but my Belkin N1 Vision, is fast as ****...
Red
