Wireless Router for VM 50MB
20 Jun 2005
London..
So after all the wireless issues I am having with the super hub I've decided to get a separate wireless N router and put the super hub into modem mode.
I don't really want to shell out too much but these are the candidates I've come up with on a budget:
Belkin
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8233uk4&aid=10288&scid=0
D-Link DIR615 ( can get for about £10)
http://www.dlink.com/DIR-615
Or if anyone can recommend me some other routers which will give me the most of the 50mb connection and better range that would be great.
Thanks
Same situation as you - superhub is utter garbage and no matter what settings are used there are always issues with it, even when I had the laptop no more than 2 feet away from it!
Bought myself an Asus RT-N56U last week (on special deal) and what a transformation! Easy to setup, and now I get reception everywhere at home with no dropouts whatsoever.
Bit pricey at £90 but for that you get essentially 2 wireless routers (2.4ghz & 5ghz) and all your problems would be gone!
Netgear WNR2200. It is N Wireless, USB Storage enabled & used for Virgin Media Connections. It is £40-£50 from different stores/shopping places, (online & in-store).
