The 3 storey building I'm moving in to only has one wireless router which is on the ground floor. The signal is actually better than I'd expected, but ideally I'd prefer a cabled connection to the router.
There'll be 2 PCs in the flat, both of which need to be connected to the router via network cable.
Here's a diagram that explains the situation:
As you can see from the diagram, there's a problem.
Question: Is there such a thing as a splitter of some sort for cabled network connections? A way of connecting the 7m network cable to the end of the 30m one? A bit like if you have 2 electrical devices plugged into one power socket through a splitter.
The router cannot be moved by the way.
Thanks
Thanks
