Wireless router to Wireless access point.
18 Aug 2009
Hello guys...
I really really... need help with the following problem.
I got a Wireless modem/router from my ISP thompson is the brand. I also have a dlink DIR 615 wireless router and a netgear Wireless Access point WG602.
Now the problem is that i my ISP's modem/wirelessrouter is in the kitchen and i need to get in my room a wired connection. So i thought if there is any way to connect the one router with the other and take a wire from the router in my room.
Or should i just buy a powerline ? does it affect your speed?
I hope you can understand what i mean...
Thanks for reading :)
You are asking if you can create a wireless bridge with the kit you have - chances are probably not.
Powerlines are good, but speeds can vary. But if it's just to get internet in the other room, then they are great as you should get internet speeds across them fine.
